flexible diamond pads for the RG 130 grinder??
markie mark
I've had great luck using the 130 grinder to resurface my exterior house surrounding concrete driveway/walkway. I used the silver wheel which did an amazing job but would like to use the same grinder to blend in the coarseness of the process. It's an old home with many differing concrete pours throughout the years, I'm not looking for flat and wouldn't be able to achieve if desired, just wanting to blend out the swirls and occasional dips. thanks.
@markie mark There are no flexible pads for the Renofix. Have you thought about an angle grinder as a finishing tool? I've never tried to smooth out masonry with it, but i imagine a fiber disc pad attachment with some suitablly aggressive abrasive might work for this application.
The dust collecting capacity of the 130 is what I love. An angle grinder would kick up too much dust. Thanks though.
Good to know, then it becomes more about finding a flexible backer for a diamond pad, probably an hook and loop pad. Amazon has junk stuff and hard to sort through.
