FlipStop v2.0 for TPG Parallel Guide System - now even better!
TSO_Products
Retailer
Maybe it's a bit of a stretch that the old adage, “You can never have enough clamps,” applies to FlipStops as well. But, having additional FlipStops on hand can really speed up your work—especially if you find yourself constantly moving back and forth between the same rip cuts.
Today we are launching our TPG FlipStop v2.0 pre-configured from the factory for right-hand or left-hand use. Now it's easier than ever to add these little time-savers to your TPG system. Pick up an extra set today!
What sets the TPG FlipStop v2.0 apart from all the other FlipStops on the market?
* Exclusive Calibration Memory™ collar eliminates the need to re-calibrate the FlipStop when switching between Standard and Narrow Stock Rods
* The fastest-to-calibrate on the market
* Parallax free cursor makes it easy to read T-track dimension and dial in your exact setting
* Comfort Grip Star Knobs for quick lock and release, even with gloves on
* Internal spring loading feature means even when the FlipStop knob is loosened, you won't accidently move it along the T-track as you turn the Star Knob to lock in a setting—a common problem with lesser material stops
[size=18pt]Learn more about our FlipStop v2.0, a key part of the TPG Parallel Guide System!
