I have for sale a Makita sliding compound miter saw. This is the 12" blade with laser and built in florescent light.
Built-in laser with micro fine adjustments clearly indicates line of cut; independent switch allows laser to be seen independently of blade rotation
* Built-in high output fluorescent light illuminates work area and lasts 2,000 hours on average
* Dual steel rails supported by linear ball bearings ensure stable, accurate cutting
* Powerful, direct drive 15 AMP motor never slips or bogs down
* 9 positive stops at 15?, 22.5?, 31.6?, 45? left or right and at 0? for the most common miter cuts
* Bevel positive stops at 33.9? and 45? left with 45? right
* Electronic speed control maintains constant speed under load; soft start feature for controlled operation
* Single cast aluminum base has built-in wrench storage for operator convenience
* Long slide track and wide pivot angle allow cross cuts up to 4 x 12 material
* Large turn base and adjustable pivot fence supports larger stock
The cheapest that I have found this saw advertised is $549. Amazon wants $599 Amazon
I have had this saw for less than a year and have used it very little in my hobby shop. My saw is flawless and immaculate and does not appear to have been used at all.
I am asking $400 and since it is so large, shipping would not be possible, so local sales only.
