Free standing LumberRack
tiralie
I have to clean up my work area to make some space so that means I gotta move some lumber out and store it somewhere.  I built a temporary stand for some material and drying racks etc. but I always meant to make a larger rack that could accommodate my 10 ft. long stock.
As this rack will sit outside, with a cover, and may be moved at sometime I really wanted to make it free standing and not attach it to a wall.
After looking at a number of lumber racks online, I designed this one.
[attachimg=#]
Here is an exploded view of the uprights and the components.
[attachimg=#]
I have been looking for the steel equivalent, a one-sided cantilever rack, for my shop. I like your design, but wonder if it could hold the weight of a full stack of MDF?
A frame racks are the industry standards for mobile racks.  You have two sides and it is easy to attach wheels and not worry about tipping.
No, I don't think so.
A sheet of MDF weighs about 95 lbs. give or take a couple pounds.
A lift of MDF is 44 sheets. That's about 4,1800 lbs or slightly over 2 tons.
Have a look at these cantilever racks.
I really only designed this rack for left over solid stock from other projects. My sheet goods will stay in the car port. If this rack fails, I will be buying one of the medium duty I linked to above.
Tim
Sparktrician said:
Nice idea, Tim, but why did you choose to invert the top bracket?
Thanks. The top bracket will serve as support for the roof. When I move this indoors I will invert the top bracket and use it to store stuff.
gkaiseril said:
I would consider putting longer foot behind the racks for dimensional lumber for sheet goods.
Wood Storage 101, Lumber Storage and 7 storage tips
I don't plan to store sheet goods on this rack...but I won't say I'll never store sheet goods on it [big grin].
I have reached the maximum width for the space I plan to put this rack. You really can't swing a dead cat in the space but it's a good place to store extra/unused lumber.
Tim
If your interested in a steel rack check out used material handling suppliers
I've picked up several nice racks at a fraction of the new price
Tim, can't the uprights back about 5º, lookouts about 2.5º up from leve it will change the load path. This should reduce the risk of tipping forward.
Got it.  Thanks for the clarity.
