I'm selling what's needed to get up and running using half-sheet sandpaper (non-hook-and-loop) on a RS2E. If you use your RS2E heavily this can save you money on abrasives, outside of that, the Vitex paper is excellent.
This includes:
Festool 485647 RS2E Sanding Pad for half-sheet paper
Festool 481523 RS2E Hole Punch for half-sheet paper (also useful for some Makita sanders)
Qty 10 each of 80, 100, 120, 150, 180 and 220 grit VSM Vitex sandpaper -- 60 sheets total, made in Germany.
I cut in half and punched one of the half-sheets of 80 grit but did not use it, the sanding pad has some sanding dust on it but otherwise is new -- used for less than 2 minutes.
Mr. Alan Little has some videos posted about this solution at https://www.google.com/search?q=site%3Ayoutube.com+askwoodman+sandpaper which are worthwhile viewing.
$150 + shipping (likely flat-rate Priority Mail will be best option).
Thank you in advance!
This includes:
