Lou Miller
- Jan 22, 2007
No, not Geico my car insurance is really low already, but Gecko...http://www.bobmarinosbesttools.com/...d=5015fde44698acbe337e4f6975308dc1&pid=493507
Anyone have one? I have a job that I'm starting tomorrow morning where I have to cut a lot of window sills without removing them from their openings. Long story, but I'm installing new windows in a customer's house and the openings have to be altered a good bit. So I bought an 800mm guide rail and a Gecko. I'm hoping to be able to attach the Gecko and the rail to the sills and use them to make all of my cuts. The sills have a very nice clear coating of some kind on them, but I'm not sure what it is. I'm guessing its a varnish. The sills appear to be Elm and they are awesome, so I don't want to use any type of fasteners to attach a straight edge. Regular clamps might work (not sure about that), but they'd probably be a real pain in the neck since I have so many to do.
Anyway... I tried the Gecko out on my bench (which is hardboard on the top) and was dissapointed with how well the Gecko held. I cleaned the top with a vac, then I also wiped it down with some naptha (so it would dry fast). It takes very little force to be able to shift the rail and the Gecko no matter what I try. I'm hoping that its the hardboard, because the rail doesn't even hold any. I'm making all of my cuts with a router (OF1010) and a straight bit. If I were just using the TS55, I probably wouldn't be as concerned.
Does anyone else have one of these (I don't suspect that many people do, but you never know), and how's it working out for you? Any cleaning process that you've found works better than another? I'm hoping that the sills I plan to use it on will have more bite than my benchtop does. If you have one, please post your experiences with it.
Thanks.
Thanks.
