Hi, everyone
Hoping that more-experienced forum members can give me some ideas on how to solve this problem: I'm working on my workbench top - it will be 2 inches thick from Appleply (I'll face-glue two 1-inch pieces). Now, the TS55 I have does not cut 2" with the guide rails. I have thought of two possible solutions:
1. Glue the two pieces and cut to size running the saw AGAINST the rail instead of ON the rail, but I'm afraid the cut will not be straight or that I'll get some nasty kick-back. Is this doable (as in "will I get a good, straight edge?")
2. Cut one of the pieces to the exact size BEFORE the glue-up and cut the second one, say, 1/8" bigger. Then, glue them up and use a trim bit with my router to make them even (this is my "solution" so far, but I wonder how smooth/even the joined edges will be)
Any other solutions or improvements on my ideas? What would you use as your glue for this project? I'm trying to decide between Titebond III and 3M's 90 Spray Adhesive. Cauls or temporary nails for clamping? Any ideas will be appreciated.
Thanks in advance!
Thanks in advance!
