I happen to be one of those lucky people that Nick is talking about who is completely satisfied with my Kapex and has not had one bit of trouble (other than the price) since I bought it.
Just to be on the safe side though, maybe you shouldn't hang out with Nick too much after you buy it.
I would suggest a 36mm hose instead of the 27mm. The 36mm just seems to collect more dust. About 95 percent or better compared to 85-90 percent.
You may want to consider a dedicated shop-vac for it. The saw pretty much filled up my CT-22 dust bag with sawdust after a week or so of home use.
The handle takes some getting used to, but not that much. I kinda follow the opinion that a handle in line with the saw blade will have less deflection on the cut. Besides, it makes it easier to cut left or right handed.
This saw really packs a punch for it's size and weight. I don't have enough room in my shop to keep a SCMS just sitting out all the time, and can appreciate being able to put it up on a shelf easily when I need room for something else. This was a major consideration for me and my small shop.
I would recommend this saw for it's accuracy, capacity, quality, ease of use and size. I have had zero regrets.
This is not a saw I would loan out though. It's not the type of saw you can just chuck in the back of your truck and let bang around. Functional, yes. Accurate, you bet. Robust, eh...time will tell.
Good luck on your decision
Greg
