Rutabagared
- Jan 27, 2008
Bad bad Gibson.
Now I know why I never liked their guitars.
William Herrold said:Corporations have been supporting illegal harvesting practices for far too long.
Not sure how you came away with that, but anyway...
If found guilty, Gibson should be made an example of and fined in the 7 figure range. Corporations have been supporting illegal harvesting practices for far too long.
Dig a little deeper and you see an issue about not enough milling was done on the wood in india, according to our gov't.
he was having most of the work done here, when they only want you to be able to buy it in veneer form from there.
Hi William. You might want to read the affidavit, because none of the charges involve illegal harvesting. If you read paragraphs 7, 8, 10, 12, 14 and 17, you'll see that "Warner Construction" is correct. A better copy of the warrant is at this URL:
http://graphics8.nytimes.com/packages/pdf/arts/GibsonWarrant.pdf
The charge is that Gibson broke a U.S. law that says Gibson is not allowed to break India's law regarding the exportation of wood products. The scandalous thing is that the Indian law has nothing to do with the environment. Rather, it's a law that restrains trade in a way that favors the Indian wood processing industry over foreign wood processing industries. In other words, Gibson has been charged with violating an Indian "corporate welfare" statute. (Ironically, if you understand the economics of tariffs, you'll understand why the Indian law harms the people of India as well as foreigners who want to buy wood products from India.)
The specific Indian law at issue is section 2.29 of its Foreign Trade Policy, which is described in paragraph 17 of the warrant. Section 2.29 prohibits exportation of wood products that fit the description in section 4407 of the "International Tariff Code," which is quoted in paragraph 10 warrant. Section 4407 prohibits the exportation of wood products "sawn or chipped lengthwise, diced or peeled, whether or not planed, sanded or end jointed, of a thickness exceeding 6mm." In other words, if lumber is 6mm or less in thickness, it can be exported, regardless of what species it is. The full text of section 4407 can be found at this URL:
http://www.cybex.in/indian-custom-duty/Wood-Sawn-Chipped-Lengthwise-Sliced-Hs-Code-4407.aspx
(For what it might be worth, paragraph ten of the warrant contains a typographical error that changes the meaning of the quoted text of section 4407: the phrase "of a thickness" was mis-typed so it reads "or a thickness".)
So there you go--If guilty, Gibson is guilty of violating an Indian law that favors Indian businesses that process wood at the expense of Indian businesses that want to sell unprocessed (or less processed) Indian wood in a more competitive market that would include foreign buyers.
Regards,
John
