Dan,
I have the DeWalt DW735 planer and I like it a lot. As a matter of fact, I just got through planing all the hard maple for my new butcher-block counter top and it did a wonderful job! As you probably know, it has two "modes": dimensioning and finishing. I have used both modes and only see a slight difference, as the dimensioning mode leaves a glue-up-ready finish. The controls are really smooth, with a nice big handwheel and an easy-to read ruler.
After running all the maple for my counter top, I finally had to switch the blades. The blades are double-sided, so you get more use out of them. A whole new set is expensive (about $50), so I am glad to hear that DeWalt has made them more long-lasting.
When I searched for a planer, I carefully compared the DW735 with the Ridgid, Delta, Makita, and other models. In the end, it was a very close call between the Ridgid and the Dewalt. I felt that the DW735 had just a bit more going for it.
This was my first planer, and I've learned a bit about planing while using it. The DW735 is fairly expensive, especially if you outfit it, as I did, with the roller stand, outfeed tables, and dust bag. Altogether, the package for me was about $620. The dust bag does, at best, a decent job. It does help with getting the majority of dust in one area, like a small garbage can, but when you remove the cover, a lot of the debris falls onto the floor. Plus, it doesn't help too much with the finer dust.
Snipe is one of the issues that comes up with planers. Since this was my first planer, I don't have anything to compare it to, but I have not had any problems with snipe. The rollers pull the wood through nicely and the tables support stock well.
If I had to do it again, I'd probably go with a 15" or bigger planer, as some here have suggested. I like the one Powermatic makes. There have just been so many times when I could have used that extra 2" or 3". But then again, if I had a 16" planer, I'd probably wish for a 20"...
The one thing to think about is blade changing. With the DW735 it's unbelievably easy. There are indexing tabs that put the blades right where you need them, aligned perfectly. I think on some of the bigger planer, aligning the knives ends up being about the same as doing it in a jointer, and you know what a pain that can be.
Bottom line: The DW735 is definitely a nice planer, with really good blade changing and controls, but a bit on the expensive side.
By the way, I wrote a review of this planer on Amazon a while back, which can find by
clicking here.
Matthew
