P pgrbff Member Joined Feb 8, 2016 Messages 19 Jan 29, 2020 #1 The press button that is pressed to stop rotation on the OF1400 to remove the router bit no longer works on my router. It has done very few hours, is there a DIY fix? The button to secure the bit still works.
F forestmount Member Joined Apr 8, 2018 Messages 23 Jan 29, 2020 #3 This sounds like the same user error I encountered after a few hours of DIY. The power has to be turned off for the lock to work. Sent from my iPad using Tapatalk Pro
jjowen Member Joined May 27, 2015 Messages 148 Jan 29, 2020 #4 Check that the trigger lock button (on the side of the handle near the power trigger) is released. That should fix it.
P pgrbff Member Joined Feb 8, 2016 Messages 19 Jan 30, 2020 #5 ben_r_ said: Are you out of the 3 year warranty? Click to expand... Unfortunately yes
JeffSD Member Joined Sep 5, 2019 Messages 47 Jan 30, 2020 #6 jjowen said: Check that the trigger lock button (on the side of the handle near the power trigger) is released. That should fix it. Click to expand... Bingo! I had the same problem.
