Hey Mav, I have used my ets125 for sanding mud and it works great, but i don't use my ct22, i use a shop vac with the drywall bags, and i haven't had any problems. As far as paper and grit, i use Mirka's abranet using just 320 grit. I found with the abranet that you get nearly 100% dust extraction and no clogging of the paper, plus with the 320 there is less of a chance that you will cut too far. Ive done drywall for a while and my first and second coats don't even need to be sanded. (Unless special circumstances occur, but thats beyond the point) But i don't know if you do a lot of mudding, so try the 320 and if it doesn't cut enough for you then try 240, don't go any lower though cause there is too much of a risk that you'll cut into the drywall. Hopefully we are talking about the same thing, as far as "plaster" goes cause diffrent parts of the country refer to "plaster" differently. By the way, using the abranet with the festool sander and vac, i don't even have to cover anything up in the house, there is virtually no airborn dust whatsoever. Hope this helps.
