UK Government Health and Safety Executive has published an information sheet at
http://www.hse.gov.uk/pubns/wis32.pdf entitled "Safe collection of woodwaste: Prevention of fire and explosion".
One paragraph of this document reads as follows:
The explosibility of woodwaste
Assume that all woodwaste is potentially explosive,
unless a dust explosion test demonstrates it is not.
Woodwaste usually has a dust explosion risk where the
mean particle size is less than 200 microns and where
as little as 10% of the mixture contains dust less than 80
microns in size. Only weak explosions are likely where
the mean particle size exceeds 200 microns.
Woodwaste is commonly produced by:
- fine cutting (eg sanding) which produces a dust of
very fine particle size. This is usually assumed to
be explosible;
- machining and sawing softwoods which produces
chips, shavings and coarse dust with only a small
amount of fine dust. This does not normally create
an explosion risk, so long as the fine dust is not
allowed to separate and accumulate within
confined spaces;
- sawing and machining hardwoods which often
produces woodwaste containing considerably more
dust than that from softwood. Assume this is
explosible ;
- the processing of MDF, chipboard and similar
boards by machining and sawing. This can be
expected to produce waste containing much fine
dust. Assume this is explosible.
When mixed processing of a variety of woods and boards
occurs, assume that the waste produced is explosible.
A second leaflet, titled "Wood dust: hazards and precautions HSE information" is at
http://www.hse.gov.uk/pubns/wis1.pdf and one paragraph reads:
Each year premises and plant are severely damaged or
destroyed by wood dust fires and explosions.
Concentrations of small dust particles in the air can form
a mixture that will explode if ignited. Such concentrations
usually occur in dust extraction equipment which can be
destroyed unless special precautions are taken. Such an
explosion can also dislodge dust deposits that may have
accumulated on walls, floors and ledges which in turn
can ignite causing a secondary explosion.
Although aimed at industrial premises, it may be interesting to some FOG members. More leaflets relevant to woodworking are available at
http://www.hse.gov.uk/pubns/woodindx.htm
Forrest
