Bugsysiegals
- Mar 19, 2016
I’ve been noticing more tear out than I’d like to see while using the track saw. Thankfully it's just drawer box bottoms which will be hidden in the dado's but I need to resolve this issue as this would be unacceptable on exterior cabinet panels.
I've noticed a decent gap between the blade and splinter guard and that it appears jagged and not straight ... is this expected? Would forcing the cut to fast or a dull blade cause some deflection of the blade? I checked the side to side play of the saw and while it didn't appear to move I could see the Black plastic tabs which protrude through the top of the saw by the side to side adjustment knob moving a tiny bit. I tightened the adjustment knobs until these no longer move and the saw is now a bit stiff but a small price to pay for eliminating any side to side deflection.
I recently readjusted the blade angle on the TS 55 which wasn't that far out of square and I wouldn't expect that to be the cause of this uneven/jagged gap which seems larger than from some small blade bevel angle adjustment?
Can the splinter guard be removed, moved out ~2mm, re-applied, and re-cut rather than buying an entirely new one which I'd need to do for the FS 1080 I've shown below as well as likely my FS 3000 and FS 1400?
View attachment 1 View attachment 2
