rmwarren
- Jul 11, 2010
This idea is not original but I got motivated to make it a few days ago while reading the thread on Woodpecker's framing square and seeing how Seth used it for cross-cutting plywood.
Today I stopped work right at 5:00, walked out to the work-shed and had it completed by 6:30. Granted, I am set up for simple metalworking and had everything I needed on hand.
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
The 2 legs are each 600mm long. Total materials needed are 4' of 1/4" by 2" aluminum flat bar, a dozen M6 cap screws, leftover rail clips from my Rip-Dogs adventure (the secret ingredient...) and a couple t-nuts. I drilled the through holes to 1/4" (6.35mm) to give the M6 screw a tiny bit of wiggle room so I could tweak the alignment to square the "T" and snug the leg against the guide rail.
It wouldn't be too hard to replace the the guide rail clips with something shop made, but that might take nearly as much time to make as the rest of the parts together.
Have not tested it but I can't see any reason it would not be dead-on square with a bit of tweaking.
Thanks for looking.
RMW
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
Thanks for looking.
RMW
