dollar bill
- Jan 24, 2015
Does anyone know if the bottom of this item, once installed on a 1400 router, will be at the same level as the base of the router?
I want to make sure I can do this before I spend $60 + tax on this tool. If I understand you correctly I can put both rods through the base as usual, put one of these guides on either side of the router (on the rods), and the router and both guides will rest on the work surface at the same time?Frank-Jan said:Yes, I use it alot when using the edge guide, on the other side of the router as a table widener to easier balance it.
I want to come up with a creative way of making the router base larger by putting some real estate on both sides of the router. I am making a shallow bowl (6" diameter) using a bowl & tray bit and the base of the 1400 is too small. I'm not thrilled about making a shop-made base so...Doable in this manner?Crazyraceguy said:Yes, but why would you want to? I'm not seeing the point of trying to use 2 rails with the router between them?
I wouldn't be using rails. I would have the router on rods and I would use 1/2 of the guide stop on either side of the router. A bridge of sorts. The guide stop halfs would ride on top of the template as the bit cuts the workpiece. Would this work?Crazyraceguy said:If you have the router "suspended" between to rails on the rods, it can't do anything but move ina straight line. How would this work on a bowl?
I did not realize this item is not flat on the bottom. I think I'll just have to bite the bullet and make a shop-made base. Thanks for your help.Crazyraceguy said:I guess it would? but they really aren't intended for anything but riding on the rails. They are not all that flat on the bottom because they are normally just holding the router in relation to the rail and sliding on it.
What you are looking for is more like an "outrigger". I would think that this is something that is better built to fit the situation. Using a drill press to drill some holes into some wooden skis seems like a smoother approach.
I'm making a larger base as we speak. I purchased a piece of 12X12X1/4 acrylic and some longer screws (M4X.7X12mm). We'll see what happens.Crazyraceguy said:Here's a pic to better illustrate the bottoms of the guide stops. The one on the right is for the OF100 the other pair is for the OF1400.
The pic flips over when you enlarge it? that's wild
