Guide Stop FS-OF 1400 questions
festal
Hello all. Just got Guide Stop FS-OF 1400 for my 1400.  Is the micro adjustment inifinte or does it bottom out?  Also is there a correct orientation or it doesn't matter if microadjustment is closer to router or away from the router?
I seem to either unscrew the micro adjustment or get it locked at the other end of the scale.
Here is how I got it setup.
I generally run mine further to the left (of your pic) with the base of the router partly on the rail itself.
Then drop the little follower/foot down to keep it supported. This puts one of the adjuster mechanisms outside the rail. You can put either side of the pair toward the router, it doesn't matter at all.
Thank you.  I have an older rail so no second t-track. Is the micro adjust limited to certain range? Or is it unlimited?
There is definitely a limit to it. The little green wheel is attached to a threaded shaft. The limitation is the length of those threads. I couldn't tell you how much travel there is though, I have only moved mine maybe 10mm at most.
