Hand sanding block hsk velcro foot
Tobiasz
Hi. About hsk sanding blocks. Are velcro element holding sanding paper replacable when die across time?
I googled “replacement Velcro for Festool husk sanding block”.  There appear to be options, including two on Amazon, though those appeared to have a foam pad.
I don’t use the system, so I did not delve further.
No.  By the time the velcro dies, the rubber should be close to dead too.  I'm impressed if you killed it already.
No...I have the 3 foam versions and also the plastic HSK-A 80 x 130.
I think they don't offer the option because it's a hand sander and not subject to the heat and sanding forces that can be generated by a motorized sander.
