hdv
- Nov 13, 2017
Like some of you I am the owner of a few Felder/Hammer machines. For the table saw I have an eccentric clamp that can be mounted on the slider. It is a great clamp and I have no gripes about it. However, that thing is just too darn heavy to use for simple "one-off" jobs when it is not on the slider already. So I modified a Bessey clamp to use in such cases. I thought maybe others might have use of it as well.
Take a T-track (in this case from Incra) and saw off a short length. Make sure one of the holes is about in the middle of the short piece of T-track. Tap a thread in it (I used M6). Find a set screw in the corresponding size (again M6 in this case). If the end is not flat, make it flat. In my experience it will grip better and not damage the T-track. You will need to file it anyway, because you want the screw to be long enough to reach the clamp and short enough not to protrude from the T-track (see photo's). Put the piece of T-track over the clamp. Tighten it with the set screw. Voila, now you have a quick clamping solution for the slider. Of course this is not the right tool for heavy clamping, but for most smaller jobs it will do.
HTH
A short piece of T-track with a screw hole in it.
The piece of T-track with the set screw.
[attachimg=2]
The same piece of track with the filed off side of the set screw visible.
[attachimg=3]
The assembled contraption.
[attachimg=4]
[attachimg=5]
The clamp in use.
[attachimg=6]
HTH
[attachimg=2]
[attachimg=3]
[attachimg=4]
[attachimg=5]
The clamp in use.
[attachimg=6]
