Exodies said:
If I’ve counted correctly that’s two happy TKS 80 owners.
After several months I’m still trying to get mine aligned and have the workpiece not hit some edge while feeding it.
Two who replied here. Doubtless there are many others across Europe who just use it and don't even know about FOG!
What's catching? The throat plate is easily adjusted. The protractor fence when used on the sliding table on mine was catching until I actually levelled the table with the main table surface.
The rip fence will catch when moving it if you're using the right hand table extension and haven't seated it correctly after removal/refit. It will also not be parallel with the blade in such instances. Both of which are operator error, I don't mind admitting it anyway.
Finally, check that the riving knife is actually centred with the blade. It's easily adjusted, and something I do when I fit non-Festool blades to mine as they're two different kerf widths.
Not exactly a 'catching' kind of cause, but remember to actually adjust the levelling leg adjuster if you've moved the saw around. It can leave the table top high on two opposing corners if you haven't adjusted it. Won't bother a builder in most cases, but worth checking if you're using it for finer work. It will make a difference and it's something I think others overlook or take for granted when they're complaining about the table flatness.
I'm still using mine several times a week, and still very happy with it.
If you have some feedback on what's causing you trouble, folks will try to help. It's up to you if you want that, or want to complain.
