Need advice on aligning Kapex (recent purchase) for a perfectly straight bevel cut. Cutting a 1 by 6 board across for a routine cross cut is perfect and straight across the 6-inch face, as well as dead-on 90 degree to the board's edge. However, when I tilt the blade to a 45 degree bevel, the cut is no longer straight across the face; rather, it is off by a lot, 1/8 inch or so. Same results whether left or right tilt. The 45 degree angle is a perfect 45 degrees. What am I doing wrong???
Thanks.
Thanks.
