Justin Michael
- Oct 10, 2014
Hopefully someone can explain what's going on. I set the fence to 45 degrees, and set the scale to 11mm (not the stop block). My understanding is the scale sets the distance from the fence to the centerline of the bit. I cut some 6mm mortises and found that they were actually 14mm on center.
It's important that these mortises be accurately placed as i am butting the miter to the face of another board and i need the edge of the miter to line up exactly with the edge of the other board. if they are off by 3mm, the miter comes up short of the edge of the other board.
I've read both supplemental manuals but they were silent on this issue. I think it has to do with where the fence pivot is located, but i'm not sure. Any insight would be appreciated.
