Help on systainer labels
Superchippy
Hi firstly apologies if posted in wrong section
I have a large number of systainers that I've printed off labels previously
4 per systainer
This was a long process only being able to print one label at a time
Is there a way to print multiple labels per sheet this would save me time and paper as I intend to use a high grade printable glossy card
I did see a pic where a chap had multiple labels per sheet
Thanks in advance
I'm on a Mac so this works for me. Pull up the .pdf label you want to print. When the print screen comes up there are several options towards the bottom of the window.
First change Copies per page: from 1 to 4
Then go up to Scale: and put in 100%
Print
[attachthumb=1]
