SoonerFan, I am happy with the saw. I also looked at the Mafell, because of the greater depth of cut and greater power, but, like you, I could not justify the cost. I think it is silly that Festool didn't add the additional 3mm to the saw blade diameter to ensure a clean cut on 2x American lumber. That said, Sedge did a demo where he made it work. He had to push down a bit more than was reasonable, but he got there. I'll do the same trick and make it work for 45s. Otherwise, I have to say that the saw is really handy. In a week of ownership, I have used it a ton, and I have been really glad to have it.
If you get one, double check a couple of items on the rail. The first rail I received had a very brittle splinter guard strip. I've never seen that before on a Festool rail. Those strips are usually soft and pliable. When I went to trim it, it literally chipped and splintered, sending shards toward my face. Not good on any account. The second thing on that rail was that the alignment numbs on the bottom were not quite right. I was about 1/32" out of square on a 10" cut. Sam at Highland Woodworking kindly replaced the rail, so problem solved.
