After a few days of cutting a roof in the rain (Seattle...) the track isn't retracting smoothly after a cut. The spring loaded clip on the track is functioning properly. I cleaned the tool thoroughly everyday with a blow tip.
The problem actually seems to be the resistance of the blade guard against the track is holding the track back.
I was thinking about lubricating the point where the guard contacts the track. I'm wondering what the appropriate lubricant would be?
I don't see an obvious adjustment for track retractor tension or blade gaurd tension.
