A jointer serves two purposes. First it is used to flatten one side of lumber. Secondly, when that face is put up against the fence and pushed thru it will then create a face at a user set up angle to the flattened face.
Using a router table as a jointer will only deal with the edge. If you are buying your materials pre-planed so that the two faces are parallel and flat, then you could use a router table. A track saw on a rail can speed up the edge jointing process.
The HL850 on the stand will have a very limited ability to flatten a face based on its limited width. On edges it would have a capacity to handle a wider variety of lumber.
