Hello everyone.
I would very much appreciate your thoughts about what hose/accessory options are appropriate for the CT22 that I hope to buy in a few days.
My usage will primarily be in my garage/shop, in a variety of general shop vac roles. Some general clean up, some sanding applications, etc.
I do not own a chop saw, and don't see one in the near future.
I do hope to acquire a TS55 or equivalent soon for sheet goods work.
I do expect to buy the "hose garage" and use it for normal hose and cord storage. The vac will park on the garage floor when not in use. I will almost never need to transport it away from home.
My first inclination was to buy the "compact" tool set (456736) which has a variety of tools for ~$70.
These are listed as 36mm tools -- I presume they will work with the 37mm hose -- is that correct?
When is the larger diameter 36mm hose adviseable? If there is a substantial advantage to using that for general use, then perhaps the "tradesman" set is more appropriate; but at ~$200 it isn't something that I'd jump into without some good justification.
So any thoughts about hose size, and when to consider anti-static hose over the non AS hoses would be helpful.
Thanks in advance. I'm still amazed that I'd consider plunking down this kind of cash for a vacuum, but my existing shop vac is so doggone noisy it drives me nuts.
I hope this gives you an idea of how & where the unit will be used. Any thoughts are very much appreciated.
-Tom Henderson
Ventura, CA
-Tom Henderson
Ventura, CA
