P
		putttn
Guest
Man, just spent two frustrating hours trying to figure out the boom instructions.  Typical German effort to try and explain something.  That's about the worst effort I've ever seen.  With all the good things why not finish the job and explain exactly what goes where.  The final straw is the large hose is supposed to fit into a clamp according to what I could figure on the instruction sheet.  Only problem is the jaws of the clamp are too small to go around the hose so now what?  The screws in the clamp are barely long enough to get a bite on the little bolts that slide in their seperate grooves.  If I could have got ahold of that stupid Kraut engineer who tried to write the instructions you know where the vacuum would have ended up!
