speed said:thanks for the replies guys [big grin]
i will look for a uk supplier of techflex or similar, as im getting fedup with catching the hose on things
Sal LiVecchi said:RMW I have to wonder what kind of weight this would add to the vac hose. I will say that as cover would be tough to hurt in almost any circumstance for sure.
Sal
The easy way to get the power cable and hose into a sleeve is to put the plugit into the tool end of the hose. With the 27mm hose just the front of the plugit goes in.RMW said:Sal LiVecchi said:RMW I have to wonder what kind of weight this would add to the vac hose. I will say that as cover would be tough to hurt in almost any circumstance for sure.
Sal
Dunno. The stuff my Ace Hardware stocks was not very heavy, it may be lighter than the image I found online. I will grab a piece and report back.
I did buy some of the braided poly that (I believe) Toolnut sells, it works great but getting the hose/cord into it was like stuffing a rattler into an anaconda, both were fighting for all they were worth...
RMW
Ken Nagrod said:Just something I thought I should throw out there. Electrical wire/cords have a temperature rating related to their amperage carrying capacity. When you enclose a cord, you are also insulating it and preventing the heat (from current flow) from escaping which lowers the amount of amps it can effectively carry. Shouldn't be a problem for the plug-it cords used on most of the Festool power tools, but some like the higher amp draw tools may have issues or trip breakers. In other words, the possibility is there, so keep that thought in mind when choosing a cover. The looser, the better.
Shane Holland said:
