antss said:[member=23193]PreferrablyWood[/member] - why would the attic cause an issue with strength ?
Seems to me the strength is in the frame / outside edge just like on a regular systainer. [unsure]
antss said:Perhaps you should actually look at one in depth. The attic makes the SYS main body no more or less water resistant. It seals onto the main body the same as a regular systainer lid.
Given enough volume of water and time , I'd bet capillary action will let water through the clear lid of the attic flap though.
But, I don't leave my stuff out in the rain. So it seems moot anyway , even if it were possible. Which I'm not going to test.
I think the systainer is reasonable as far as water getting in when out in the rain for an hour or so , but there is no tight seal of the lid to the base so I would not trust it for longer periods out in the weather with things that were water sensitive like sandpaper or powertoolsAlex said:The systainers are protected against rain just fine. I've had plenty of -involuntary- opportunity to test this the last 2 months.
antss said:I just find it strange that some of you leave your Festools out in the rain [eek] [eek] [eek] [eek]
I don't even treat my old crappy no name tools that way.
I wouldn't want the xtra weight, or expense of weatherizing the systainer. And you'd lose the smooth closure too. If I needed or wanted a a serious duty case to protect from the elements and abuse , I'd get Pelican cases and have the tools fitted to them.
It is interesting and should be noted that Dewalt's new case system has been weatherized with a gasket. I've only taken a cursory look at them, but I find those too heavy and bulky for my tastes. I'm sure they appeal to many guys though.
