sofa_king_rad
- Mar 26, 2016
I was going strong on my first project, then we had a baby and I've barely touched it in nearly 7 months. NEEDING to get this done i've start scheduling time each week for it.
It's a twin sized bed frame for my daughter. I have the footboard frame roughed out, domino'd and ready to sand and glue EXCEPT for the 1/2" plywood panels that will go on the inside. I have a couple questions.
Should I do a rabid cut on each side all the way around the plywood? I don't see any benefit in this other than being able to cut a smaller groove in the Rails and Stiles, which are like 2.5" thick, so it isn't necessary. I can just cut a 1/2" dado, right?
So for the panel, it will just float in the grooves correct? How deep should the groove be, I have plenty of room. Is 1/4" normally enough or should i go 1/2" or even more? I haven't cut down my plywood yet, but the panel opening are about 14" x 27".
Hopefully i'm explaining this correctly. This all would have been easier had I just found some plans we liked and did that, but we didn't and I'm building on my on design, simple as it may be.
Again this is my first project.
