I've searched the forum and can't find any relevant information related to this. I am looking for information on choosing the correct domino length for various applications. In understand the concept of using a domino thickness that is 1/3 of the material or using multiple dominos in a large joint for increased strength. I've also read a number of articles on mortise and tenon. However, the general rule of thumb for length with M&T appears to be simply that the tenon is at least twice as long as it is wide. We obviously have significantly more options that with the domino system. What I can't find is any information on when to use a 8mm x 100mm domino vs a 8mm x 40mm domino. Should I always use the longest domino that will fit in the material? This would seems unnecessary in many cases, but will this create the greatest strength is solid wood (ie material that is equally as strong as the tenon-not plywood or MDF)? Any information would be very much appreciated.
