How does the antistatic chain work?
guitarchitect
I'm working on putting together a separator for my CT26, and since I will need to use some PVC I wanted to ensure I preserve some anti-static qualities. I got a grounding kit which should be fine, but I was curious about the conductivity of the festool hoses.
My thinking was - if they're anti-static, they would be conductive. I checked the resistance between the ground tab in the hose inlet on the CT26 and the ground on the plug - all fine, the needle jumped the way I would expect. When I checked the two ends of a hose - nothing. When I plug in the hose, and touch a probe to the outside of the hose and the ground plug... nothing.
So - am I confusing grounding with anti-static? Is the benefit of the hoses that they dissipate static charge rather than ground it? Or is there something else at work that I'm missing? We have very dry winters and I do get a lot of static (and shocks) on my PVC flex hoses to my dust collector, so I definitely want to ground the PVC.
Alex said:
Every part of the hose is conductive and connected to the ground.
Yes, I understand that. I just don't understand why it doesn't register on a multimeter the same way the ground strip to ground plug does.
However, there's a clear explanation in the link [member=66126]wpz[/member] posted, so thank you for that! didn't find that thread when I searched for it!
Multimeters use a too low test voltage. If there is the tiniest gap... it will see no connection at all between test terminals. If you apply a higher voltage you can bridge small gaps.
That's exactly what was done in the linked topic with an insulation tester at 500V.
