How I hang my track saw tracks horizontally
bwehman
I searched for a bunch of solutions when looking for a way to store tracks horizontally, and didn't find anything I was quite keen on. So I played around with some ideas and landed on this.
Basically, it's pegboard hook screwed into this plywood situation that lets the track rest on a rail rather than the splinter guard, which most seemed to do. Really well supported and works great! Figured I'd share for future searchers looking for ideas.
Very neat and well designed, they (FS) don’t rest on the splinter guard I presume?
Very nice color scheme on the walls of a very tidy garage  [smile].
I love these peg panels, it’s a sort of MDF? They were very common to get in sheets here before, now special order from most places. It’ll be mandatory when I get my final space (shop).
Great job!
That’s a great design....and cheap!
I use the Fastcap version, but mount them upside down so it rests on the back of the rail vs the splinter guard.  Also use them in the garage door as I don’t have the wall space to mount horizontally.
I have all of mine mounted vertically. The 1080 and 1400 hang from the hole in the end and the longer 1900 and 3000 stand on end in a rack I made for my 98" Bessey clamps.
I'm in a huge shop where space is not an issue at all, but my area is out in the middle of open space with no actual walls. I have a short back wall behind the run of Sysport style cabinets, but it's only about 12 feet in length and less than 5 feet high.
I would move the long rail supports more to the centre, so you minimize the "bend" moment which is perpendicular to the reference plane in this position. I do like the approach on the hangers though.
Supports at 25% and 75% length are optimal. Bend forces are the least that way.
I am sure I haven't seen all the different pictures of how people store their rails but all the ones I remember being stored horizontally seem to always have the splinter guard down. Why? Why not just flip them over so the back is down?
I have noticed that too and wondered the same thing.
Here is what I did. Made from some scraps.
Maybe it will help someone.
I store mine horizontally in a simple way- just hanging over two nails through the holes on each end of the rails. The nail are at upward angle and I push the tracks flush to the wall. Haven’t seen any bowing issues (yet)... should I be careful about that issue especially on the longer 2700mm rail?
Here is my setup
I hung them splinter guard down only because the Festool logo faces that way...pure aesthetics [emoji3]
Yes.
If you have a known-good straight edge with a high-enough accuracy class you would be able to measure this. With a supports distance int he 2600+ range for a 2x200 mm aluminum alloy profile, you will see a self-weight bend of about 0,1 mm/0.004" in the center.
That is NOT an issue short-term during use as it is well into the elastic range for aluminum alloys. However long-term the bend can become permanent and create a new, bent, "no-stress-shape" for the material.
Every metal alloy has a certain range of "plasticity" where if there is a long-term stress the material will "accept" the new shape before it reaches a point where the crystalline structure is able to prevent further bending. This is a non-issue for a structural element (the support will not bend beyond this plastic threshold) but is a big issue for measuring instruments which rails kinda are as far as accuracy requirements go.
In general, the only 100% correct way to store the rail is vertically or -fully- horizontally with a low surface friction - i.e.upside down or on slippery "casters" so the anti-slip mats cannot create a bending force.
That said, there are limits into how much this is a practical problem.
I would say the 1400 rails are "on the edge" of where it is safe to hang them just by the holes. The 1900 ones will probably be still fine but with the 2400+ rails I would be careful and the 5000 one is an absolute no-go.
A 1400 rail supported only on edges get self-bent only around 0,006 mm i.w. about (2650/1350)^4 = about 15-times less than a 2700 rail does. What is more important is that the same low bending as for the 1400 one applies for the 2700 rail if supported at 25% and 75 % length. Critical is the maximum distance between the supports not the actual rail length.
Note:
Unless you can guarantee supports being exactly in one line horizontally (hint: you cannot *) using more supports DOES NOT help.
The self-weight-bending gets approximately (2^4=) 16-times worse for each multiplication of this distance by 2.
*) Well, you kinda can, using equal-force springs to hang the rails. But that is very much impractical and for the 2400-3000 length rails more than two supports are an overkill anyway. Place the supports at the 25/75 locations and should be fine.
I don't have much wall space so I hang all of my smaller rails vertically.  I used to have a dedicated place on my lumber rack to store my 3000 but that was bound to get me in trouble.  I have some storage attached to my ceiling so I created some C brackets and attached to that storage.  They are spaced 32" apart and I have 4 of them.  So far this is very sturdy and keeps it out of harms way.
Great idea. Thanks for sharing. I have joists every 24” so can take their support to store the 2700 rail horizontally.
An upside down label is maddening. This is the way.
