Jmacpherson
- Jun 9, 2016
I'm trying to determine whether the jump in price between a CTL36 E AC HD (currently on special here) vs the CT26 and other models is worth it?
I currently have a CT17 which isn't available in the NA. Has a 17L capacity, 3700L/min flow, 24000Pa suction and the filter area is apparently 4600 sq cm.
The Midi in comparison has 15L, 3700L/min flow, 24000Pa suction and 5000 sq cm filter - basically the same.
The 26 and 36 have the same suction as above but 3900L/min flow and large filter area.
I came across this comment on another forum which was debating M-class extractors:
"I have a CTL midi (L Class) and a CTM 36 AC (M Class). Both have stanard bags and 36mm hoses, the same 1200W power rating, but completely different levels of suction. The CTM36 puts the midi to shame, especally when used with the Kapex saws."
Is the extra 200L/min making that much of a difference?
I'm already using a 36mm hose.
Wanted to check with other FOG users who switched too the large units if they noticed improvements?
Besides performance improvements, the larger capacity and long life bag are also a factor.
Weight and size doesn't bother me because it will stay under my MFT permanently
