- Nov 14, 2013
I am back to working on my 'possible' workshop trailer design. One wall will have the Kapex along it, with a table structure made of 8020 extrusions. The table will have 8' plus of surface on either side of the Kapex blade. and will have systainer storage both below and ABOVE the table on each side, with a CT under the saw itself.
Here's a screen shot of my 'work in progress' that I really just started. Ignore all of the detail as it will change, but it should help visualize the concept:
[attachthumb=1]
It's the storage ABOVE the 'side wings' that I am wondering about. How much room would you want or need from the side 'wings' up to the bottom of the rack that supports the upper systainers? The depth of the upper will only be what is needed to fit a single systainer from front to back. That currently looks like it will be 350mm deep.
The height of the wings will be 900mm, to match an MFT if needed. So how high above that (or off the floor) would you make the bottom of the support structure? In other words, how much clearance would YOU want to maximize storage space but still allow comfortable room to work on anything from crown moulding to ?
[attachthumb=1]
