ThisVeteranVlog
- May 14, 2020
Greetings fellow festoolers!
After picking up a DF500 from a two year break from woodworking, I have made many projects with it in the last few months. Recently, I have been redoing all of my oldest daughters furniture in her room; 16 drawer modular bed, bookshelf, desk, wall shelf and a floating night stand. I used lots and lots of butt joints with the Domino, and occasionally would foul up the plunge location and not discover the issue until the dry fit. I even had to toss out a carcass for the bed project because of how messed up the alignment was on the bed project. An expensive mistake when it comes to 18mm 11 ply baltic birch.
In most of the center shelf butt joint videos I've seen, it was merely a demo unit with only one end of the center shelf being shown on how to plunge the two pieces for a successful butt joint. I've yet to come across a video that shows doing both sides, much less a good way of marking everything to line up the face grains as references.
After doing some thinking, I came up with a method of marking a workpiece that uses one or multiple center shelves or some type of center cross member. I made a video showing the process in my first (and currently only) You Tube video to get error free center members.
Thanks for looking and I hope this helps some of the other DF 500 newbies out there.
https: //youtu.be/vvFLDYaOAUo
remove the space after ":"
How to Make Perfect Butt Joints with Festool Domino
