How do you go about sanding a piece of wood that is thiner than the bench dogs that hold it? I have a piece of supawood that is 6mm thick and I need to sand it. However the bench dogs on my mft are higher than the thickness of the wood so I end up hitting it. Does anyone have any simple/ easy solution to this beyond trying to prop it up with other wood underneath it?
Chris
Chris
