photos please! I’ve shipped many electronic fragile things in the past. Cardboard between the table and moving blankets. Harbor freight sells moving blankets. I have a 14 foot enclosed trailer it has an axle rating of 1750 pounds. The legs depending on size I would put four in a box bubble wrap legs. The could go on the other side of the table to balance out the weight. You might consider adding styrofoam peanuts to the box. I’m assuming you have a pickup truck? I would probably make at least two trips? However I would be tempted to stand the tables up on edge, bubble wrapped and then use the leg boxes to hold the load together. Or boxAcarper76 said:I just completed 13 twelve foot tables and 54 six foot
Benches and now I have to prep them for travel 10 hours away. Legs are not attached. How would you package the tabletops and Bench tops?
Alex said:I don't know how drivers licenses work in the USA, but the number of large tables and benches sounds too heavy for what you can move with a standard car license and needs to be moved by a cargo truck.
Rick Herrick said:I am betting that if you supplied a couple of pictures, you would get more informed suggestions.
DeformedTree said:Class C license (what everyone has when they say "drivers license") allows you to operate up to 26,000lb GVWR.
