I have the OF 1010, 1400, and 2200 - Is the MFK 700 duplicitous?
bwehman
Like the title says, I have all the routers. The 1010 is even the newest one. I know there are edge trimming attachments for the 1010, but the MFK seems to do it with more elegance. Given the rest of the routers I have available, would the 700 just basically be an edge-trimming machine? Or does it excel at other applications even in the company of the other three?
Great trim router and excels at flush cutting banding as well as edge profiles. I really like its versatility.
Well, if you have the other three... I would definitely only use the 700 for edges.
I recently purchased my first Festool router, the MFK 700.  I got the set with two bases (The Q?)...
I have other routers.  I have a homemade edge trimming jig (with an older Dewalt DW110, that has been the dedicated edge trimming set up).  I have a few bigger routers and a another trim router.
Yesterday was my first full day with the 700.  I just happened to need it to trim a bunch of edge banding...  I would say it saved me hours...  Just yesterday!
Now, maybe the 1010 has a similar edge trimming system (I haven't spent a lot fo time drooling over Festool routers...  Need to get busy, though!).  But, I cannot see the ergonomics being as effective as the 700.  It was so easy and light....  Plus, I had it dialed in so tight, I honestly barely need to sand.
Like I said, I am new to Festool routers.  My old shopmade setup worked okay.  It got the job done, kinda accurately, cumbersomely slowly, and required a lot of sanding afterwards...  as well as, somehow, messing up the surface veneer more often than I care to admit....  I may not have enough experience with the other Festool offerings, but I will say, after one day of experience with the 700, I would buy it all over again.  Actually, I would buy it again several times over.  (I'm actually contemplating another one already).
Ah, the treachery of too many routers. [laughing]  You probably want to use “redundant” and not “duplicitous”.
You cannot have too many routers.  I have two P-C 690s so that I can leave the dovetail jig set up all the time and just dive right in when I need drawer boxes with no setups.
I have one router in a table, one trim router that’s really easy to handle, and a couple more somewhere.  You cannot have too many routers.
Exactly! better words were never written. Put simply, You cannot have too many routers.
Having specific set-ups is very handy and saves a lot of time and hassle.
The MFK700 is a little more of a specialized tool though. I use mine with the horizontal base 95% of the time. If you have the need for this specialty, sure go for it, otherwise a OF1010 might do you better.
