Lots of useful info’ in the responses here. Want to add to the mix (appreciating some duplication on my part.)
You say the painter complained about ‘orbital scratches,’ not the grit you finished on; guess he knows what he can work with (after all we don’t know what paint ‘system’ he’s using.)
Presume your time important + cost of abrasives; so you don’t want to do unnecessary work whilst prepping for the painter.
Just curious. Realised unsure as to your work flow. Was the sanding all done before final cutting and assembly? Reason I ask is, that it’s one thing to be sanding everything horizontally – quite another if some sanding done vertically, into corners etc, with closet assembled and in place. In the same sense, is any painting (priming/undercoat maybe) to be done before final cutting/assembly. Don’t really want to get into the pro’s/ con’s of different approaches – only wondering.
As Rubin used, obviously closet made from wood; but what sort of wood? If ‘softish’ maybe consider using a hard pad (if not already).
Totally agree with what Timtool says. Personally, wouldn’t really expect to have to use the ‘course’ mode at all. Would pretty much expect to be able to go straight in at say 120, just as final ‘once-over.’ In this context, you say finished on 100, but not what you started on, or, at what points you used ‘course’ or ‘fine’ mode.
Basically, never start at a lower grit than necessary, and, always use ‘fine’ mode (at the same grit) after ‘course’ sanding – make sure any scratches are really gone at that stage before moving to next higher grit.
Sometimes I get a bit crazy, depending on my mood and the job; will use tack clothe, after brushing down(vacuuming) surface – even between ‘course’ and ‘fine’ sanding at same grit – even sometimes brushing (or vacuuming) the abrasive sheet itself – to ensure no trapped particles affecting the surface.
I routinely only go to 120, (particularly if primer/undercoat being used - paint has a job to do as well), but I understand that some modern paints prefer 150, or even 180. That said, definitely wouldn’t spend time going higher than necessary. Maybe check with the painter?
Regarding abrasives. Lots of good suggestions already given. I will use Rubin on bare wood, but the blasted stuff wears out so quickly. Looking forward to getting people’s impressions of Rubin 2; but I have existing stock to use first. Have been known to work through Saphir grits for that reason. For some reason, like to use Brilliant for final sand.
Got a lot of time for Granat, but primarily on painted/mixed surfaces – doesn’t tickle my fancy regarding wood – especially in lower grits.
LOL. What alternative sander(s) would quench your Festool thirst?
Well, if you really don’t want to go for an RO150, then you’ve covered ‘course’ sanding.
So much depends on what you’ll use it for doesn’t it? Lots of suggestions already given.
For me, the DTS400 is essential - for getting corners etc, with decent dust collection. The attributes of, the ETS150/3 or /5, and ETS125 often discussed – reading between the lines, reckon the ETS150 would suit you better.
But...I love my RS200 ½ sheet. Only prob’ is, the large footprint gets in way sometimes – so for that reason, the RS300 (1/3 sheet) is definitely on my wish list – particularly with long pads being available for it. Seems to me that the 2.4mm orbit really hits a sweet spot. Also, not at all bad for some lower grit sanding.
Suspect I’d really like the DTS400 / RS300 combo for what I do a lot of – backed up with the RS200 for larger flat surfaces.
