Im looking for an excuse to buy and RO150 will this do???
sessler2013
I am needing to refinish our hardwood floor in our foyer and am thinking that it would be an excellent excuse to buy a RO150, we have 400sq feet to sand, and yes I know it will take longer to do with an RO150 as apposed to renting and actual flooring sander but at least in the end I would have a tool I can keep, and as long as I get a Festool out of It I really don't mind spending hours on my knees sanding. My only concern would be the end result of the floor would their be any disadvantages to a RO150 (other than the time it would take) as opposed to a floor sander?
If you count the pickup and return time it is probably quicker to buy the RO150. It will only take a short time to knock off the old finish if you use the rotary mode.
That is quite a big area but with a kneeling pad or knee pads you will do fine. If you use a Festool CT with the RO150 then you will hardly make any dust at all. I agree with the comment made by the other OF5 that the Rotex may be quicker in the long run and also I bet by the time you add the consumables and hire charge it must make sense to have a tool that will then take you through many more jobs like this.
I have been using my Rotex 150 a lot today and it is equally at home doing delicate work (finish sanding on a walnut desk) as it is doing tough jobs like the one in question.
I would buy Granat at 80 and 120 grit but others may have better advice.
Thanks guys that's exactly what I was wanting to hear, sounds like my stack of systainers is going to grow yet again!
And don't forget to get the polish pad as it is also great for polishing the car which I do often
Yes! I was thinking also about doing that and using it to polish our granite counter tops as well, does anyone know what pad would be best for granite?
Personally I would want the sander best suited for the job, and I would expect a wood flooring sander to be it.  I am not a professional wood flooring installer, but I did do my own floors at home (about 1000 square feet), and I would never consider using just a 6" hand held sander to do it.  The sander I used covers 216 square inches with its pad.  a 6" round sander covers 28.26 square inches.
Not that a festool sander couldn't be used as part of the job.  A RO150 might work well for edges and corners, or even a RO90 since it has a delta head.
agreed with above and I own ro 150&90.I would still go rent the floorsander,but then there's the planex,maybe that would be a good excuse to own one
With your member name and living in Texas, you must be a shooter also. Can't go wrong with woodworking and shooting.
Marcus
