Michael Kellough said:
Thanks for the interesting info and ideas Charles.
You said, "...make sure the starter winding is not open. Depending upon where the centrifugal switch is located, you may be measuring an open switch instead of an open winding."
Can you explain this, measure where?
If you have an ohmmeter, or continuity tester you can determine if there is low resistance across the starter winding. The starter winding circuit consists of the winding, centrifugal switch and capacitor in series, and is energized when the power is placed across the two motor input terminals.
You know from inspection which two wires are connected to the capacitor, but you don't know how the wires are connected to the input terminals and the winding. If both the switch and the winding are not open, the resistance from each of the wires that were attached to the capacitor to one (and only one) of the input terminals should be relatively low (less than 10 ohms, I would guess). If this is not the case, I would suspect the switch or the winding. A motor connection diagram or physical inspection can help you determine which is the culprit if there is an open circuit. Note, when testing, only use an ohmmeter or something that produces DC (like a battery powered continuity tester). You don't want your motor taking off on you.
"As mentioned previously, capacitors can fail in a spectacular way. You didn't notice anything in that regard. However, those motors probably used capacitors that were in metal cans and were not electrolytic."
My capacitor looks good, no visible signs of failure at all, (no foul aroma either) and is the dry electrolytic form. If it went south should there be some sign?
Also, if you have an ohmmeter, you may actually be able to get some idea of whether the capacitor is working. With a big resistor (eg a megohm) in series with the capacitor, if you measure the resistance of the pair, it will start out at the value of the resistor, and then increase to infinity. For a 20 microfarad capacitor this will occur in 20 seconds or more. For a 2 microfarad cap it will be more like 2 seconds.
"Dirty contacts happen all the time. The centrifugal switch is buried inside the motor. If you have an air hose, you may be able to make some headway without having to disassemble it."
I did previously (15 years ago) have a problem with dust in the motor (it smoldered!) which inspired me to make some changes inside the tub so I could add dust collection. I had to disassemble the motor then to get it really clean. It certainly wouldn't hurt to blow it out and see how much stuff has gotten in there.
"You can always try using a push stick on the blade to get the motor rotating in the right direction."
To try this, would I need to shunt the wires that went to the capacitor, or put the capacitor back in?
Thanks Charles!
Don't shunt the wires to the capacitor. That will almost surely burn out the starter winding. Leave them open. The purpose of the capacitor is to phase shift the current going into the starter winding. This produces a relatively small but effective torque to get the motor running in the correct direction. After coming up to speed, the centrifugal switch shuts off the starter winding, which is no longer needed.
When the motor on my old Harbor Freight drill press would no longer start on its own (due to both capacitor and starter winding failure), I would hand start it by spinning the chuck in the correct direction. I don't recommend this 'hands on' method for getting a table saw rotating. Use a push stick.
Charles
