Interesting new dust collection machine
Obviously not for the hobbyist, but looks great for the production shop.
Very interesting.  Thank you for sharing this.
Krkww said:
Take note on the specifications page at the bottom: it is 3 phase.
No its not 3 phase, its 12A single phase.
The motor is 3 phase, but its powered by a single phase supply via a siemens inverter.
Regards
Dale
Woodwork Wizard said:
Almost 4,000 dollars and it's the size of a small car?
I'm very happy with my CT-36 and an UDD on top.
Not sure where the reviewer got 4000 dollars comes from, its $2950 delivered to your nearest port, to me that is delivered into Southampton UK,  its also only 1.4 m long x 800 mm high, thats a VERY small car ;-)
Dale
Regards
Dale
Ah yes, I stand corrected. Thank you sir.
I think that Bridge City Tools is offering to sell these at $3995. They may have signed a dealer agreement with the manufacturer for US sales.
Clearly out of my league...but reviewing the specs it's rated at 5 micron.  That doesn't seem great to me for $4k...am I missing something?  I'm asking seriously - to me that seems like the most important factor w.r.t. my health, is there something different about this machine I'm not seeing?
I am always interested in a better mouse trap for dust collection.  This thing looks very cool, but I am doubtful it is truly better than a competing dust collector, with the exception of noise and size.
It's hard to know how this will truly perform because there's not enough data provided.  Many dust collector vendors provide a graph, showing a range of CFM vs. static pressure, and with that, and knowing the length of pipes, bends, etc. you can estimate the actual CFM.  With this, they only provide CFM for a "hose" -how long is the hose?  BTW, their 6" hose CFM comes to 764.  I measured my CFM at the end of my pipe run (about 35 feet) at 1100 (Clear Vue cyclone)
More on the CFM: they have a 11.8" impeller and use 1500watts.  There's only so much CFM that you can get out of something like that, and be durable (be able to take a hit by a chunk of wood and the blades survive).
5 microns is not good enough for a standard filter, not even close.  How much is the HEPA upgrade?  I wonder how much the CFM drops with the HEPA filter.
This solution boils down to a 2-stage cyclone, first stage for big chips and second for dust.  You can do this by using both a trash-can separator and a standard cyclone.  This product's low noise, and small size, however, could be a big advantage for someone.
I would think that having a HEPA on the backend would be ideal.
I suppose if the bulk is removed then there is not a lot left. But the fine dust will clog the HEPA if it is doing its job... Albeit it will take a while.
I'm looking seriously at one of these, I will post up new details when I have them, including HEPA filtering down to 0.2 micron.
The thing that attracts me to it , it is relatively compact and its quite low noise as anything too loud Annoys the neighbours.
Dale
I like the idea and design, but it's just not "there" yet.  Discounting anything else, the fact that it's not HEPA makes it unworkable for me.
It seems a little lacking in the airflow department for anything other than single tool use.  Part of the reason I have a workshop is so I don't have to move things around all the time.  For $4,000 I can buy a fairly large centrifugal machine, 7.5 hp Griz is around $3500 for example, and have a couple hundred left to jam it in a corner and put up two soundproofed walls.
