Introducing Flat Face Bench Dogs - Perfect for Horizontal Clamping
TSO_Products
Retailer
Introducing the Flat Face Bench Dog, combining the convenience of a cylindrical 20mm bench dog body with a pivoting flat face that provides more surface area for your layout and fixturing needs. When working with traditional rectangular panels, the sides of a cylindrical dog provide a very small tangential bearing surface. If you're using cylindrical dogs with a horizontal clamp, there is the possibility of marring the edge of your workpiece, depending on the clamping strength and workpiece material utilized. By providing a CNC precision milled flat face measuring a generous 1½" (38.1mm) in width and ½" (12.7mm) in height, these bench dogs can serve as dependable fixturing aids or work stops, especially when used in conjunction with inline clamps such as our Power-Log Toggle Clamp. The dog head can also be freely rotated to accommodate angled fixturing applications, such as mitered or triangular workpieces.
[size=18pt]Shop Flat Face Bench Dogs & Other Workholding Products
What else is happening at TSO?
JUST RELEASED! GRS-16 PE v2 Guide Rail Square for Festool, Milwaukee & Makita Track Saws
"Version 2" of our popular guide rail square now includes a fast attachment feature: simply insert the square at any point along the guide rail and clamp it in place—no need to slide it into the guide rail from one of the ends or remove hose deflectors, clamps, or other accessories occupying the guide rail T-slot.
JUST RELEASED! GRS-16 PE D Guide Rail Square for DeWalt Track Saws
The proven design of the GRS-16 guide rail square has now been adapted to fit the DeWalt track saw system! Like the original GRS-16 and GRS-16 PE squares, the GRS-16 PE D makes it lightning fast to achieve dead square cuts with your DeWalt plunge saw.
MFT Aligned Upgrade Kit
Restore confidence in your MFT/3's accuracy with the MFT Aligned Upgrade Kit, which replaces Festool's stock plastic mounting brackets located on both the front and back guide rail supports with precision CNC-machined aluminum brackets. These new brackets are much more rigid and—because we're able to hold much tighter tolerances in aluminum—they also provide a more precise and uniform fit. The result is much stronger guide rail supports less prone to deflection and less likely to move out of square during normal operation.
TPG Parallel Guide System
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy and quality of your parallel rip-cuts.
GRS-16 Guide Rail Squares for Festool, Milwaukee, Makita & Triton Track Saws
Our patented designs are born square through precision CNC machining and an innovative self-aligning latch mechanism. Simply slide the square onto your guide rail and lock it into place. Five seconds to square!
Padded Storage Bags for Precision Tools
Whether in the shop or on the job site, a little insurance for your fine tools is always a good move. Check out our new padded storage bags for guide rails up to 55" in length, parallel guides, and precision triangles.
ha! the GRX-PE v2 is exactly what I tried to make in the shop recently (but chickened out). I have a sticker on my v1 that says "CLAMPS!" to remind me to put the clamp in before the GRX cuz I'd always forget until I wanted to slide it in. Nearly cut off one side of the clamp the other day to effectively make it a v2. Glad you saw the correction!
Now, the flat-face dogs should have been called "Frenchies"...  [big grin]
I really like the flat face bench dogs...I have a couple of older pairs that Veritas marketed that work really well for fixtures. I use both the 3/4" height and 1/2" height versions. I'll pick up a set of these because I like the swiveling feature.  [smile]
The new v2 guide rail square is also nice, that's a big improvement over the original.
