- Jun 25, 2016
Introducing our new TPG-20 Set. Sometimes the best tool is the smallest one that can get the job done. This systainer-friendly parallel guide system is the perfect addition to your arsenal and is the setup that we default to using most often!
Upgrade from the tape-measure-and-marking routine to a best-in-class system that will increase the speed, accuracy, and quality of your work. The TSO Parallel Guide (TPG) System utilizes two precision extruded T-tracks attached perpendicular to your guide rail with two precisely machined FlipStops which engage the edge of your workpiece parallel to your guide rail's cutting line—resulting in accurate and perfectly repeatable rip cuts. The TSO TPG Parallel Guide System is compatible with any length of Festool, Kreg, Makita, Powertec and Triton brand guide rails.
We have a limited supply, so act fast before they sell out! Check out our TPG Parallel Guide System today!
[size=18pt]Check out our TPG Parallel Guide System today.
Thanks for your support, and happy woodworking from the entire TSO Products team!
