To the Festool Home Office if they care:
As a long term serious woodworker I’ve bought the following items in the last 15 years that have all exceeded my expectations and is why I’ve recommended Festool in the past to all serious woodworkers but may not in the future.
- A ATF55E saw with a CT22E, plus FS 1400/2 and a FS 1080/2 guides in 2002,
- Rotex RO 125 in Feb 2005 – used for sanding and polishing my glass panels
- Router OF 1400 EQ in Feb 2005 – used for one $3K job but not used much since
- Cordless Drill (C12) – used so much I’m amazed it still is in great shape.
- Replacement blades for the ATF55E
- Sanding pads for the RO 125
- Batteries (2) for the C12
- And other less expensive items like claps and cut guides for the FS guides, replacement bags for the CT22E, and wool pads for the RO 125 to polish glass, and so on.
So my estimate is the last 15 years I bought over $5,000 on Festool units and replacement items with excellent satisfaction.
But this June 2017 I purchased a Festool Trion PSB 300 EQ Jigsaw with attachments including the Circle cutter.
The total cost was well over $300. The use was to cut circular blanks for turntables in woods like Bubinga, Zebrawood, Lacewood, etc. at a thickness of ¾”. Well I purchased the two blades “recommended” on the Festool site for the Circle cutter. As a woodworker that doesn’t want to waste wood I used the narrower blade first. Well, about 3 inches on the 14” circle the Jigsaw started to throw sparks. The blade had bent badly and was eating up the blade guides!
I then had an online “chat” with a Festool tech (he was very helpful as to info about the saw that is NOT in the documentation). I said: "OK – but there was NO indication in the Festool documentation about this".
Since then I’ve tried to cut smaller circles, in the 6” range, and even the thicker blades fails before a full circle is cut, and YES with sparks as it bends and hits the side supports! So I could say with confidence as an experienced woodwoorker on tight cuts on really hard wood with the recommended blade this Jigsaw is not worth a piece of S___!
NET: Is anyone listening in Festool ‘s Home Office with a statement like the one on page 61 of the 2017 Catalogue – “Versatility.unmatched. The blade finally met its match” . As an experienced woodworker I’d say the PSB 300 EQ does not cut it for real hardwoods. It may be great for ½” ply or soft woods BUT don’t over sell it as something that cuts real hardwoods.
So as a serious woodworker I’d not recommend the PSB300 to any real woodworker unless they plan to use it for cutting thin stock or ply at ½” with the Circle Cutter.
An this point I plan to ask for full refund from my long term supplies (McFeely’s) based on a description of produce not meeting its specs.
George McGinn
PS I did send some of this Info via a Festool feedback form a few days ago but got no response. It was about the Circle cutter having an alignment issue and is related to a wrong angle leading to "burned" cuts and potential heat on the blade. I have not heard back. I guess they don't give much value to long term users. So I'll be looking for another company for my next tool purchase. It's the usual, get known as great, let things slip but make money, and then go out of business after 10 years.
George McGinn
