Is there a Multi Jetstream sanding pad for ETS EC 125?
Wood_Slice
I have looked around and found the 150 mm version but they list the older models as what they fit on. Can somone tell me if there is and if you have a link. If yea do they come in different hardness?
125mm are not airstream. They don’t generate enough dust. So as of now the 125mm is old school.
Thank You figured there was something there since upon searching and searching couldn't find one for the 125. I also read somewhere here that on the ETS EC 125/3 you can also attach the 150 pad. Maybe I can by a 150 multistream pad that would be same except larger pad?
