ear3
- Jul 24, 2014
So I'm doing my first job since getting the TS 75. Creating a faux oak paneled library (though with 1/4" oak veneer ply and real oak moulding) for an art installation. Because we're trying to minimize cost, we've opted just to join the panels flush and have large squares of astragal moulding in the center of each panel, rather than run battens down the seams where the plywood joins, which would start to get expensive since it is a 20x20 room. Doing it this way was predicated on having something like the TS, where I could make extremely clean and straight cuts so that there is no gap between the plywood panels.
Well, the first few cuts were disappointing. They were clean and 100% tear out free of course, but the cut was slightly concave (between 1/16 and 1/32) -- ironically, it was a result similar to the old clamping guide method I previously used. I soon realized that it was probably due to the fact that I was using two rails joined by connectors, rather than a single long rail. I reset the connectors and measured to verify that the rail was at the imaginary scribe line in the middle, in addition to either end. But every time I moved the setup to do a new panel, it would again develop a slight concavity. Fortunately there was a Festool dealer 5 blocks from the gallery, so I went over and got the 3000mm rail, with which I was finally able to get perfectly straight cuts and no gap between the panels once they were mounted on the wall.
I was just wondering if anyone else has experienced a similar problem when trying to use two connected guiderails in lieu of a single, long one, and if it is even possible to get a completely straight cut using the connector method?
