Issue with my Trion in adjusting the blade square to the base
James Biddle
Not sure if there's an adjustment I'm missing or something's wrong, but...
First, the bottom of the blade is tilted forward by about 5 degrees.  If I release the blade (also Festool), it seems to square back up, only to tilt again once I relock the blade (FastFix version).  Seems like the blade is pulled back and pivots on the lower guide.  I've got the pendulum set at zero and I don't see any adjustment.
Another issue is that I really have to use a lot of force on the base to square the base to the blade.
I'm sure I must be missing something.
